When projects complete they no longer display in the epic view. How do I have JIRA display or report the completed projects?
Hi Will,
For Scrum Boards you can use the Epics report, check here:
https://confluence.atlassian.com/display/AGILE/Viewing+the+Epic+Report
or better, you can use the Epic Work View for JIRA, it contains statistics on completed stories :
https://marketplace.atlassian.com/plugins/com.cobalt.jira.plugin.epic.EpicPlugin
I hope this helps.
