How do I make both Cascading fields required in Jira Cloud
Sudheer Kumar
October 28, 2024
Hi Team,
Need to get an error from Jira because the 2nd drop-down was not filled out for child value, and it should be required for cascading type fields in Jira cloud.
Note: ScriptRunner plug-in isn't available in our instance
Thanks In Advance!
Cristian0791
October 28, 2024
Hi Sudheer,
Unfortunatly only the firest dropdown from a cascade-dropdown is mandatory in roder to sumbit a ticket. As native functionalily you cannot set the second dropdown as mandatory.
Maybe with some plugins.
Hope this helps.
DerLMM
June 26, 2025
If you can install a workflow editor (there are paid and free ones), you can add the following:
issue.customfield_XXXXXX.child.value != "None"
This will make the child field required.
Fazila Ashraf
