×I'm running JIRA cloud so Script Runner is not available for me...
Any ideas?
Thank you.
Hi thanks, Clarissa.
Yeah, it appears validators is the way to go. However, when I follow the instructions in the link you gave me I am unsure which option to choose (sorry, I'm sort of a newb). Could you please advise?
Also just FYI, I am adding this prior to the "Done" transition in Agile Simplified Workflow if that makes a difference.
Thanks again,
Carlos
image2015-5-29 11:52:45.png
Hi Carlos,
plugun is not available for JIRA Cloud.
https://answers.atlassian.com/questions/303317
Regards
Chander Inguva.
Hey Clarissa, thanks so much for the info! I'm trying the instructions but I'm not quite sure which option to pick and this Q&A forum won't let me post images in this box -- only in the answer box. So I put it below and can delete it after you review it. Thanks again.
Actually, you can't. Worklog validators are not available for Cloud if I remember correctly. There's certainly none in the core and I don't remember any of the available addons providing it.
