How do I make logging work mandatory when marking issue as complete?
Carlos Aguilar May 29, 2015
I'm running JIRA cloud so Script Runner is not available for me...
Any ideas?
Thank you.
Hi thanks, Clarissa.
Yeah, it appears validators is the way to go. However, when I follow the instructions in the link you gave me I am unsure which option to choose (sorry, I'm sort of a newb). Could you please advise?
Also just FYI, I am adding this prior to the "Done" transition in Agile Simplified Workflow if that makes a difference.
Thanks again,
Carlos
image2015-5-29 11:52:45.png
Chander Inguva
May 29, 2015
Hi Carlos,
  • Please refer to this page. Hope this helps. Currently Script runner
plugun is not available for JIRA Cloud.
https://answers.atlassian.com/questions/303317
  • You can use Validators to make loggingf work mandatory.
Regards
Chander Inguva.
cgauterio
May 29, 2015
Hi Carlos,
You can use workflow validators to achieve that.
Hope this helps.
Clarissa.
Hey Clarissa, thanks so much for the info! I'm trying the instructions but I'm not quite sure which option to pick and this Q&A forum won't let me post images in this box -- only in the answer box. So I put it below and can delete it after you review it. Thanks again.
Nic Brough -Adaptavist-
May 30, 2015
Actually, you can't. Worklog validators are not available for Cloud if I remember correctly. There's certainly none in the core and I don't remember any of the available addons providing it.
