How do I mention an issue's reporter or assignee?
arthur_conde
September 6, 2023
When adding a comment to an issue in Jira, is there a macro or shortcut that will automatically be replaced with the respective @mention
For example, if I wanted to mention an issue's reporter in a comment on that issue, how do I do that without looking up the reporter and typing their name?
Helen Rastetska
Hi @arthur_conde,
If you use Jira automation for your purposes, then the following will work:
[~accountId:{{issue.assignee.accountId}}]
[~accountId:{{issue.reporter.accountId}}]
Helen
Collista Lewingdon
@arthur_conde
Are you trying to do this manually or via automation? Knowing this will help to direct our answers in a manner that is most likely to resolve your question.
arthur_conde
September 7, 2023
@Collista Lewingdon I am doing this manually. Is it possible? All other solutions I found were for automation.
Collista Lewingdon
I have not found a way to do this manually.
