I create a Google Custom Search account and modify a simple Virgil code in JIRA v5.1.3. (http://atlassian.wpengine.netdna-cdn.com/developer/Virgil/VirgilCode.txt)
I know Virgil will not work in the Quick Create/Edit dialog.
I create issues via the normal Create Issue screen. But, it does not work.
Hi Ian,
In regards to your inquiry here, I have posted a response and a sample Virgil code which was tested against JIRA 5.1.3 in the support ticket that you had raised in our support system. May I know if the sample code provided works for you?
Thanks.
Can you provide us with the sample code that was tested against JIRA 5.1.3? Thanks!
Please refer to hyperlink:
https://docs.google.com/file/d/0B1Kw-EOmqotcckI4ZWd5Y2taMVE/edit?usp=sharing
I inject the code to the description of the Summary field, via Administration > Field Configurations > Select the applicable field configuration > Edit the Summary field.
Thanks.
