How do I read "Issues in Epic" programmatically ?
ohmkaar kambhampati
July 1, 2014
Hi..
I have JIRA Agile plugin installed in my jira and i want to read "issues in epic" for a given Epic from jira listener.
Is there any API i can use to read "Issues in Epic" from jira listener?
I tried reading like a subtask as follows but it didnt help!
Collection<Issue> subtasks= issue.getSubTaskObjects();
Any help?
Thanks in Advance!!
Ohm
Yassin
This can be done on two steps:
1- Rest call
2- Extract issues from the Server Response JSON String
1-
public String getIssuesForEpic(long epicID) {
String ServerJSONOutput = NULL_DATA;
try{
Client client = Client.create();
client.addFilter(new HTTPBasicAuthFilter(JIRA_ADMIN_USERNAME, JIRA_ADMIN_PASSWORD));
WebResource webResource = client.resource(JIRA_URL + "/rest/agile/1.0/epic/" + epicID + "/issue");
ClientResponse response = webResource.type("application/json").get(ClientResponse.class);
log.trace("REST Response to getIssuesForEpic() = {}",response.getStatus());
ServerJSONOutput = response.getEntity(String.class);
log.trace("Output from Server .... {}", ServerJSONOutput);
} catch(Exception e){
e.printStackTrace();
return ServerJSONOutput;
2-
Use Java JSONObject to go through the issue array and convert them into issue object using IssueManager.getIssueObject(long id)
ohmkaar kambhampati
July 1, 2014
Looks like i found one workaround.
These links are stored in jira database as issue links.
select * from issuelinktype gives me
/10500Epic-Story Linkhas Epicis Epic ofjira_gh_epic_story/
so, for the moment I can read it from database table issuelink by querying on linktype.
ohmkaar kambhampati
July 1, 2014
I even tried accessing these like issue links. That didnt help either.
