I have imported projects into our Swanly Issue view but I am unable to rearrange them. I would like to put them in alphabetical order but I don't see any way to move them around.
I have tried dragging the projects around but that doesn't work. I tried going to the settings of the issue settings but I don't have any options other than mapping the story points field and connecting the Swanly dates to Jira.
Our roadmap looks like a mess and it's hard for me to find anything. Please help!
Nevermind, I found it! I had to go to where I would add a project and you can drag/drop them into a different order and also remove them if needed.
Leaving this here in case anyone else needs it!
I'm Nikki from Jexo, makers of Swanly. I'm happy you found your way around 👏 If you need any additional support you can always reach out to us via our support portal.
