How do I release using Kanban with Next Gen and make tickets disapear from the board?
Jennifer Greyling January 13, 2020
Hi, I used Kanban before and it used to have a button in the Board to release.  Once released, the tickets that were DONE were removed from the Board.  With Next Gen, I don't see the option to release.  So I tried adding a Fix Version to each ticket, moved those tickets to DONE, and then released from the Releases menu, but the tickets still remain in the board.  How can I make them go away?  Thanks.
2 accepted
Fernando Bordallo
January 13, 2020
Hello @Jennifer Greyling
To answer your question: How can I make them go away?
On next-gen Kanban boards, the issues that reach the DONE column will 'disappear' after 2 weeks. This is not configurable at this point in time.
The alternative, to gain a little more control, is to add sprints.
Jennifer Greyling January 14, 2020
Thanks!  I hope this can be configured soon :-)
Like Fernando Bordallo likes this
John Funk
Hi Jennifer - you might refer to this other post for guidance:
https://community.atlassian.com/t5/Jira-Software-questions/How-do-you-manage-releases-on-next-gen-boards/qaq-p/914518
There short of is that there is no way to do releases right now on Next-gen boards.
John Funk
