I am wondering if anyone has any code or gotten code to work through a scriptrunner listener to remove a particular component value on an Issue Created event.
I created an Issue Updated event listener to clone an epic with its stories. The trigger will be to add a Component of Clone Epic. Well I want to create another listener based on Issue Created event to remove the Clone Epic component from the newly created Epics.
Any advice is welcome.
Thank you in advanced!
I was able to accomplish this by using labels and creating two behaviors. First Behavior looks at the Issue_Updated Event and adding the label Clone_Epic. Upon adding this label, it clones the epic with the stories and subtasks.
import com.atlassian.jira.event.type.EventDispatchOption
import com.atlassian.jira.issue.*
import com.atlassian.jira.event.*
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.label.*
import org.apache.log4j.Logger
def loggedInUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def customFieldManager = ComponentAccessor.customFieldManager
def issueManager = ComponentAccessor.issueManager
def issueLinkManager = ComponentAccessor.issueLinkManager
def issueFactory = ComponentAccessor.issueFactory
def subtaskManager = ComponentAccessor.subTaskManager
//def issue = issueManager.getIssueByCurrentKey('CPSPLAT-1698')
Issue issue = event.issue
def changeHolder = new DefaultIssueChangeHolder()
LabelManager labelManager = ComponentAccessor.getComponent(LabelManager);
def labels = labelManager.getLabels(issue.id) as String[]
def value = labels.find {it == /Clone_Epic/}
//Create a clone of an issue
static Issue clonedIssue(Issue issue, ApplicationUser loggedInUser, IssueFactory issueFactory, IssueManager issueManager) {
def cloneIssueFactory = issueFactory.cloneIssue(issue)
cloneIssueFactory.setCreated( new Date(System.currentTimeMillis()).toTimestamp() )
def newIssueParams = ['issue': cloneIssueFactory] as Map<String, Object>
issueManager.createIssueObject(loggedInUser, newIssueParams)
def epic
if (issue.issueType.name == 'Epic' && value) {
//Cloning of the Epic
def epicClone = clonedIssue(issue, loggedInUser, issueFactory, issueManager)
epic = issueManager.getIssueByCurrentKey(epicClone.key)
def epicName = customFieldManager.getCustomFieldObjectsByName('Epic Name').first()
def originalEpicName = issue.getCustomFieldValue(epicName)
epicName.updateValue(null, epic, new ModifiedValue(epic.getCustomFieldValue(epicName), "${originalEpicName} Clone".toString()), changeHolder)
issueManager.updateIssue(loggedInUser, epic, EventDispatchOption.ISSUE_UPDATED, false)
//Extraction of Original Issue(s) from Original Epic
def links = issueLinkManager.getOutwardLinks(issue.id)
def originalIssuesInEpic= links.findAll { it.issueLinkType.name == 'Epic-Story Link' }*.destinationObject
//Cloning of Original Issue(s) from the Original Epic and Adding it to the Cloned Epic
originalIssuesInEpic.each {
def clonedIssue = clonedIssue(it, loggedInUser, issueFactory, issueManager)
def subtasks = it.subTaskObjects
if (subtasks) {
subtasks.each {subtask ->
def mutableSubtask = subtask as MutableIssue
def toClone = issueFactory.cloneIssue(mutableSubtask)
mutableSubtask.setCreated(new Date(System.currentTimeMillis()).toTimestamp())
def cloned = issueManager.createIssueObject(clonedIssue.reporter, toClone)
subtaskManager.createSubTaskIssueLink(clonedIssue, cloned, clonedIssue.reporter)
log.warn(subtask.key)
def targetField = customFieldManager.getCustomFieldObjects(clonedIssue).findByName('Epic Link')
targetField.updateValue(null, clonedIssue, new ModifiedValue(clonedIssue.getCustomFieldValue(targetField), epic), changeHolder)
return epic
import com.atlassian.jira.issue.label.LabelManager
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def labels = labelManager.getLabels(issue.id).collect{it.getLabel()}
labels -= 'Clone_Epic'
labelManager.setLabels(user,issue.id,labels.toSet(),false,false)
