How do I remove unwanted issues from a plan?
msmit259
February 9, 2023
Mark Segall
Hi @msmit259 and welcome to the community!
You have a few options:
  1. Use a filter as your roadmap issue source instead of project/board.  This would allow you to use JQL to pull in exactly what you want
  2. If the issues are of a specific issue type or in a specific status, you can exclude by status in your plan configuration
  3. If you're dealing with a small number of top level issues, you can use a plan filter to explicitly capture the issues you wish to have visible and save that as a view
