hi,
I am a confluence administrator. when I search a user, system error occurred. How can i fix it?
A display image is appeared like this
A system error has occurred — our apologies!
For immediate troubleshooting, consult our knowledge base for a solution.
If you would like to receive support from Atlassian's support team, ask your Confluence administrator to create a support issue on Atlassian's support system with the following information:
Your Confluence administrator can use the support request form to create a support ticket which will include this information.
We will respond as promptly as possible.
Thank you!
org.springframework.orm.hibernate.HibernateQueryException: Incorrect query syntax [SELECT usr FROM com.atlassian.crowd.model.user.InternalUser usr WHERE usr.directory.id = ? AND (usr.lowerName LIKE ? OR usr.lowerDisplayName LIKE ? OR usr.lowerEmailAddress LIKE ?) ORDER BY usr.lowerName]; nested exception is net.sf.hibernate.QueryException: Incorrect query syntax [SELECT usr FROM com.atlassian.crowd.model.user.InternalUser usr WHERE usr.directory.id = ? AND (usr.lowerName LIKE ? OR usr.lowerDisplayName LIKE ? OR usr.lowerEmailAddress LIKE ?) ORDER BY usr.lowerName]
at org.springframework.orm.hibernate.SessionFactoryUtils.convertHibernateAccessException(SessionFactoryUtils.java:581)
caused by: net.sf.hibernate.QueryException: Incorrect query syntax [SELECT usr FROM com.atlassian.crowd.model.user.InternalUser usr WHERE usr.directory.id = ? AND (usr.lowerName LIKE ? OR usr.lowerDisplayName LIKE ? OR usr.lowerEmailAddress LIKE ?) ORDER BY usr.lowerName]
at net.sf.hibernate.hql.QueryTranslator.compile(QueryTranslator.java:166)
caused by: java.util.NoSuchElementException
at java.util.LinkedList.getLast(LinkedList.java:122)
org.springframework.orm.hibernate.HibernateQueryException: Incorrect query syntax [SELECT usr FROM com.atlassian.crowd.model.user.InternalUser usr WHERE usr.directory.id = ? AND (usr.lowerName LIKE ? OR usr.lowerDisplayName LIKE ? OR usr.lowerEmailAddress LIKE ?) ORDER BY usr.lowerName]; nested exception is net.sf.hibernate.QueryException: Incorrect query syntax [SELECT usr FROM com.atlassian.crowd.model.user.InternalUser usr WHERE usr.directory.id = ? AND (usr.lowerName LIKE ? OR usr.lowerDisplayName LIKE ? OR usr.lowerEmailAddress LIKE ?) ORDER BY usr.lowerName] at org.springframework.orm.hibernate.SessionFactoryUtils.convertHibernateAccessException(SessionFactoryUtils.java:581) at org.springframework.orm.hibernate.HibernateAccessor.convertHibernateAccessException(HibernateAccessor.java:353) at org.springframework.orm.hibernate.HibernateTemplate.execute(HibernateTemplate.java:375) at org.springframework.orm.hibernate.HibernateTemplate.executeFind(HibernateTemplate.java:341) at com.atlassian.crowd.embedded.hibernate2.HibernateUserDao.search(HibernateUserDao.java:136) at com.atlassian.confluence.user.crowd.CachedCrowdUserDao.search(CachedCrowdUserDao.java:215) at com.atlassian.crowd.directory.AbstractInternalDirectory.searchUsers(AbstractInternalDirectory.java:549) at com.atlassian.crowd.manager.directory.DirectoryManagerGeneric.searchUsers(DirectoryManagerGeneric.java:295) at com.atlassian.crowd.manager.application.ApplicationServiceGeneric.searchUsers(ApplicationServiceGeneric.java:645) at com.atlassian.crowd.manager.application.ApplicationServiceGeneric.searchUsers(ApplicationServiceGeneric.java:607) at com.atlassian.crowd.embedded.core.CrowdServiceImpl.searchUsers(CrowdServiceImpl.java:187) at com.atlassian.crowd.embedded.core.CrowdServiceImpl.search(CrowdServiceImpl.java:161) at com.atlassian.crowd.embedded.atlassianuser.EmbeddedCrowdEntityQueryParser.findUsers(EmbeddedCrowdEntityQueryParser.java:46) at com.atlassian.crowd.embedded.atlassianuser.EmbeddedCrowdEntityQueryParser.findUsers(EmbeddedCrowdEntityQueryParser.java:63) at com.atlassian.confluence.user.DefaultSearchEntitiesManager.findUsers(DefaultSearchEntitiesManager.java:145) at com.atlassian.confluence.user.DefaultSearchEntitiesManager.findUsersAsList(DefaultSearchEntitiesManager.java:40) at com.atlassian.confluence.user.actions.SearchUsersAction.doUserSearch(SearchUsersAction.java:157) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at com.opensymphony.xwork.DefaultActionInvocation.invokeAction(DefaultActionInvocation.java:302) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:170) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.interceptor.DefaultWorkflowInterceptor.intercept(DefaultWorkflowInterceptor.java:55) at com.atlassian.confluence.core.ConfluenceWorkflowInterceptor.intercept(ConfluenceWorkflowInterceptor.java:37) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.xwork.interceptors.XsrfTokenInterceptor.intercept(XsrfTokenInterceptor.java:100) at com.atlassian.confluence.xwork.ConfluenceXsrfTokenInterceptor.intercept(ConfluenceXsrfTokenInterceptor.java:25) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.security.interceptors.CaptchaInterceptor.intercept(CaptchaInterceptor.java:49) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.util.LoggingContextInterceptor.intercept(LoggingContextInterceptor.java:49) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.core.CancellingInterceptor.intercept(CancellingInterceptor.java:23) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.security.websudo.WebSudoInterceptor.intercept(WebSudoInterceptor.java:69) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.security.actions.PermissionCheckInterceptor.intercept(PermissionCheckInterceptor.java:57) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.setup.webwork.BootstrapAwareInterceptor.intercept(BootstrapAwareInterceptor.java:26) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.user.actions.UserAwareInterceptor.intercept(UserAwareInterceptor.java:58) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.pages.actions.CommentAwareInterceptor.intercept(CommentAwareInterceptor.java:50) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.pages.actions.PageAwareInterceptor.intercept(PageAwareInterceptor.java:130) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.spaces.actions.SpaceAwareInterceptor.intercept(SpaceAwareInterceptor.java:77) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.core.actions.LastModifiedInterceptor.intercept(LastModifiedInterceptor.java:38) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.core.ConfluenceAutowireInterceptor.intercept(ConfluenceAutowireInterceptor.java:49) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.xwork.interceptors.TransactionalInvocation.invokeAndHandleExceptions(TransactionalInvocation.java:76) at com.atlassian.xwork.interceptors.TransactionalInvocation.invokeInTransaction(TransactionalInvocation.java:61) at com.atlassian.xwork.interceptors.XWorkTransactionInterceptor.intercept(XWorkTransactionInterceptor.java:56) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.xwork.SetupIncompleteInterceptor.intercept(SetupIncompleteInterceptor.java:43) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.DefaultActionProxy.execute(DefaultActionProxy.java:115) at com.atlassian.confluence.servlet.ConfluenceServletDispatcher.serviceAction(ConfluenceServletDispatcher.java:53) at com.opensymphony.webwork.dispatcher.ServletDispatcher.service(ServletDispatcher.java:199) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.refinedwiki.confluence.plugins.mobile.filters.MobileRedirectFilter.doFilter(MobileRedirectFilter.java:111) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.security.websudo.MessagesDecoratorFilter.doFilter(MessagesDecoratorFilter.java:59) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:129) at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:77) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.jmx.JmxFilter.doFilter(JmxFilter.java:106) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.ServletContextThreadLocalFilter.doFilter(ServletContextThreadLocalFilter.java:19) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.util.LoggingContextFilter.doFilter(LoggingContextFilter.java:40) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.web.filter.ThreadLocalCacheFilter.doFilter(ThreadLocalCacheFilter.java:22) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.util.UserThreadLocalFilter.doFilter(UserThreadLocalFilter.java:44) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:211) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98) at com.atlassian.confluence.util.AbstractBootstrapHotSwappingFilter.doFilter(AbstractBootstrapHotSwappingFilter.java:30) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:150) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:71) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.util.ClusterHeaderFilter.doFilter(ClusterHeaderFilter.java:37) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:72) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.springframework.orm.hibernate.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:170) at com.atlassian.spring.filter.FlushingSpringSessionInViewFilter.doFilterInternal(FlushingSpringSessionInViewFilter.java:29) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.util.ConfluenceErrorFilter.doFilter(ConfluenceErrorFilter.java:22) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.core.datetime.RequestTimeThreadLocalFilter.doFilter(RequestTimeThreadLocalFilter.java:35) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:74) at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.confluence.extra.webdav.servlet.filter.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:427) at com.atlassian.confluence.extra.webdav.servlet.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:34) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.web.filter.validateparam.RequestParamValidationFilter.doFilter(RequestParamValidationFilter.java:58) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.plugin.servlet.filter.ActionContextCleanUp.doFilter(ActionContextCleanUp.java:71) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.web.filter.LanguageExtractionFilter.doFilter(LanguageExtractionFilter.java:54) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.util.RequestCacheThreadLocalFilter.doFilter(RequestCacheThreadLocalFilter.java:25) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.servlet.FourOhFourErrorLoggingFilter.doFilter(FourOhFourErrorLoggingFilter.java:65) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859) at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588) at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489) at java.lang.Thread.run(Thread.java:662) Caused by: net.sf.hibernate.QueryException: Incorrect query syntax [SELECT usr FROM com.atlassian.crowd.model.user.InternalUser usr WHERE usr.directory.id = ? AND (usr.lowerName LIKE ? OR usr.lowerDisplayName LIKE ? OR usr.lowerEmailAddress LIKE ?) ORDER BY usr.lowerName] at net.sf.hibernate.hql.QueryTranslator.compile(QueryTranslator.java:166) at net.sf.hibernate.hql.QueryTranslator.compile(QueryTranslator.java:138) at net.sf.hibernate.impl.SessionFactoryImpl.getQuery(SessionFactoryImpl.java:295) at net.sf.hibernate.impl.SessionImpl.getQueries(SessionImpl.java:1570) at net.sf.hibernate.impl.SessionImpl.find(SessionImpl.java:1541) at net.sf.hibernate.impl.QueryImpl.list(QueryImpl.java:49) at com.atlassian.crowd.embedded.hibernate2.HibernateSearch.doInHibernate(HibernateSearch.java:102) at org.springframework.orm.hibernate.HibernateTemplate.execute(HibernateTemplate.java:370) ... 215 more Caused by: java.util.NoSuchElementException at java.util.LinkedList.getLast(LinkedList.java:122) at net.sf.hibernate.hql.WhereParser.closeExpression(WhereParser.java:301) at net.sf.hibernate.hql.WhereParser.token(WhereParser.java:241) at net.sf.hibernate.hql.WhereParser.end(WhereParser.java:283) at net.sf.hibernate.hql.ClauseParser.endChild(ClauseParser.java:100) at net.sf.hibernate.hql.ClauseParser.token(ClauseParser.java:54) at net.sf.hibernate.hql.PreprocessingParser.token(PreprocessingParser.java:123) at net.sf.hibernate.hql.ParserHelper.parse(ParserHelper.java:29) at net.sf.hibernate.hql.QueryTranslator.compile(QueryTranslator.java:149) ... 222 more
Hey guys, this is indeed a confirmed bug in Confluence that has been reported here https://jira.atlassian.com/browse/CONF-25775 . The current workaround is the same as suggested by Jeremy. Some users reported that the suggested flag doesn't work, but the following:
-Duser.language=en -Duser.region=US
We have the same problem with Confluence 4.2.3.
Please, let us know how can we fix this problem.
Thank you
Hi Abdullah,
I know you're working through this with our support team. Our current theory is that it's related to bugs we've seen before with the Turkish Locale, like https://jira.atlassian.com/browse/JRA-22386 and https://jira.atlassian.com/browse/GHS-2463. We'll post back here when we know the solution for sure.
For the record - and if anyone else comes across this problem - it was indeed the Turkish Locale. You can add a property (see http://confluence.atlassian.com/display/DOC/Configuring+System+Properties):
-Duser.country=EN -Duser.language=en
