How do I resolve searching for users?
Abdullah Çolak
January 15, 2012
hi,
I am a confluence administrator. when I search a user, system error occurred. How can i fix it?
A display image is appeared like this
System Error
A system error has occurred — our apologies!
For immediate troubleshooting, consult our knowledge base for a solution.
If you would like to receive support from Atlassian's support team, ask your Confluence administrator to create a support issue on Atlassian's support system with the following information:
  1. a description of your problem and what you were doing at the time it occurred
  2. a copy of the error and system information found below
  3. a copy of the application logs (if possible).
Your Confluence administrator can use the support request form to create a support ticket which will include this information.
We will respond as promptly as possible.
Thank you!
Return to site homepage…
Cause
org.springframework.orm.hibernate.HibernateQueryException: Incorrect query syntax [SELECT usr FROM com.atlassian.crowd.model.user.InternalUser usr WHERE usr.directory.id = ? AND (usr.lowerName LIKE ? OR usr.lowerDisplayName LIKE ? OR usr.lowerEmailAddress LIKE ?) ORDER BY usr.lowerName]; nested exception is net.sf.hibernate.QueryException: Incorrect query syntax [SELECT usr FROM com.atlassian.crowd.model.user.InternalUser usr WHERE usr.directory.id = ? AND (usr.lowerName LIKE ? OR usr.lowerDisplayName LIKE ? OR usr.lowerEmailAddress LIKE ?) ORDER BY usr.lowerName]
at org.springframework.orm.hibernate.SessionFactoryUtils.convertHibernateAccessException(SessionFactoryUtils.java:581)
caused by: net.sf.hibernate.QueryException: Incorrect query syntax [SELECT usr FROM com.atlassian.crowd.model.user.InternalUser usr WHERE usr.directory.id = ? AND (usr.lowerName LIKE ? OR usr.lowerDisplayName LIKE ? OR usr.lowerEmailAddress LIKE ?) ORDER BY usr.lowerName]
at net.sf.hibernate.hql.QueryTranslator.compile(QueryTranslator.java:166)
caused by: java.util.NoSuchElementException
at java.util.LinkedList.getLast(LinkedList.java:122)
Stack Trace:[hide]
	at org.springframework.orm.hibernate.HibernateAccessor.convertHibernateAccessException(HibernateAccessor.java:353)
	at org.springframework.orm.hibernate.HibernateTemplate.execute(HibernateTemplate.java:375)
	at org.springframework.orm.hibernate.HibernateTemplate.executeFind(HibernateTemplate.java:341)
	at com.atlassian.crowd.embedded.hibernate2.HibernateUserDao.search(HibernateUserDao.java:136)
	at com.atlassian.confluence.user.crowd.CachedCrowdUserDao.search(CachedCrowdUserDao.java:215)
	at com.atlassian.crowd.directory.AbstractInternalDirectory.searchUsers(AbstractInternalDirectory.java:549)
	at com.atlassian.crowd.manager.directory.DirectoryManagerGeneric.searchUsers(DirectoryManagerGeneric.java:295)
	at com.atlassian.crowd.manager.application.ApplicationServiceGeneric.searchUsers(ApplicationServiceGeneric.java:645)
	at com.atlassian.crowd.manager.application.ApplicationServiceGeneric.searchUsers(ApplicationServiceGeneric.java:607)
	at com.atlassian.crowd.embedded.core.CrowdServiceImpl.searchUsers(CrowdServiceImpl.java:187)
	at com.atlassian.crowd.embedded.core.CrowdServiceImpl.search(CrowdServiceImpl.java:161)
	at com.atlassian.crowd.embedded.atlassianuser.EmbeddedCrowdEntityQueryParser.findUsers(EmbeddedCrowdEntityQueryParser.java:46)
	at com.atlassian.crowd.embedded.atlassianuser.EmbeddedCrowdEntityQueryParser.findUsers(EmbeddedCrowdEntityQueryParser.java:63)
	at com.atlassian.confluence.user.DefaultSearchEntitiesManager.findUsers(DefaultSearchEntitiesManager.java:145)
	at com.atlassian.confluence.user.DefaultSearchEntitiesManager.findUsersAsList(DefaultSearchEntitiesManager.java:40)
	at com.atlassian.confluence.user.actions.SearchUsersAction.doUserSearch(SearchUsersAction.java:157)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
	at java.lang.reflect.Method.invoke(Method.java:597)
	at com.opensymphony.xwork.DefaultActionInvocation.invokeAction(DefaultActionInvocation.java:302)
	at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:170)
	at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35)
	at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165)
	at com.opensymphony.xwork.interceptor.DefaultWorkflowInterceptor.intercept(DefaultWorkflowInterceptor.java:55)
	at com.atlassian.confluence.core.ConfluenceWorkflowInterceptor.intercept(ConfluenceWorkflowInterceptor.java:37)
	at com.atlassian.xwork.interceptors.XsrfTokenInterceptor.intercept(XsrfTokenInterceptor.java:100)
	at com.atlassian.confluence.xwork.ConfluenceXsrfTokenInterceptor.intercept(ConfluenceXsrfTokenInterceptor.java:25)
	at com.atlassian.confluence.security.interceptors.CaptchaInterceptor.intercept(CaptchaInterceptor.java:49)
	at com.atlassian.confluence.util.LoggingContextInterceptor.intercept(LoggingContextInterceptor.java:49)
	at com.atlassian.confluence.core.CancellingInterceptor.intercept(CancellingInterceptor.java:23)
	at com.atlassian.confluence.security.websudo.WebSudoInterceptor.intercept(WebSudoInterceptor.java:69)
	at com.atlassian.confluence.security.actions.PermissionCheckInterceptor.intercept(PermissionCheckInterceptor.java:57)
	at com.atlassian.confluence.setup.webwork.BootstrapAwareInterceptor.intercept(BootstrapAwareInterceptor.java:26)
	at com.atlassian.confluence.user.actions.UserAwareInterceptor.intercept(UserAwareInterceptor.java:58)
	at com.atlassian.confluence.pages.actions.CommentAwareInterceptor.intercept(CommentAwareInterceptor.java:50)
	at com.atlassian.confluence.pages.actions.PageAwareInterceptor.intercept(PageAwareInterceptor.java:130)
	at com.atlassian.confluence.spaces.actions.SpaceAwareInterceptor.intercept(SpaceAwareInterceptor.java:77)
	at com.atlassian.confluence.core.actions.LastModifiedInterceptor.intercept(LastModifiedInterceptor.java:38)
	at com.atlassian.confluence.core.ConfluenceAutowireInterceptor.intercept(ConfluenceAutowireInterceptor.java:49)
	at com.atlassian.xwork.interceptors.TransactionalInvocation.invokeAndHandleExceptions(TransactionalInvocation.java:76)
	at com.atlassian.xwork.interceptors.TransactionalInvocation.invokeInTransaction(TransactionalInvocation.java:61)
	at com.atlassian.xwork.interceptors.XWorkTransactionInterceptor.intercept(XWorkTransactionInterceptor.java:56)
	at com.atlassian.confluence.xwork.SetupIncompleteInterceptor.intercept(SetupIncompleteInterceptor.java:43)
	at com.opensymphony.xwork.DefaultActionProxy.execute(DefaultActionProxy.java:115)
	at com.atlassian.confluence.servlet.ConfluenceServletDispatcher.serviceAction(ConfluenceServletDispatcher.java:53)
	at com.opensymphony.webwork.dispatcher.ServletDispatcher.service(ServletDispatcher.java:199)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
	at com.refinedwiki.confluence.plugins.mobile.filters.MobileRedirectFilter.doFilter(MobileRedirectFilter.java:111)
	at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
	at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
	at com.atlassian.confluence.security.websudo.MessagesDecoratorFilter.doFilter(MessagesDecoratorFilter.java:59)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:129)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:77)
	at com.atlassian.confluence.jmx.JmxFilter.doFilter(JmxFilter.java:106)
	at com.atlassian.core.filters.ServletContextThreadLocalFilter.doFilter(ServletContextThreadLocalFilter.java:19)
	at com.atlassian.confluence.util.LoggingContextFilter.doFilter(LoggingContextFilter.java:40)
	at com.atlassian.confluence.web.filter.ThreadLocalCacheFilter.doFilter(ThreadLocalCacheFilter.java:22)
	at com.atlassian.confluence.util.UserThreadLocalFilter.doFilter(UserThreadLocalFilter.java:44)
	at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:211)
	at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98)
	at com.atlassian.confluence.util.AbstractBootstrapHotSwappingFilter.doFilter(AbstractBootstrapHotSwappingFilter.java:30)
	at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:150)
	at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:71)
	at com.atlassian.confluence.util.ClusterHeaderFilter.doFilter(ClusterHeaderFilter.java:37)
	at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:72)
	at org.springframework.orm.hibernate.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:170)
	at com.atlassian.spring.filter.FlushingSpringSessionInViewFilter.doFilterInternal(FlushingSpringSessionInViewFilter.java:29)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
	at com.atlassian.confluence.util.ConfluenceErrorFilter.doFilter(ConfluenceErrorFilter.java:22)
	at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
	at com.atlassian.confluence.core.datetime.RequestTimeThreadLocalFilter.doFilter(RequestTimeThreadLocalFilter.java:35)
	at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:74)
	at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
	at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
	at com.atlassian.confluence.extra.webdav.servlet.filter.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:427)
	at com.atlassian.confluence.extra.webdav.servlet.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:34)
	at com.atlassian.confluence.web.filter.validateparam.RequestParamValidationFilter.doFilter(RequestParamValidationFilter.java:58)
	at com.atlassian.confluence.plugin.servlet.filter.ActionContextCleanUp.doFilter(ActionContextCleanUp.java:71)
	at com.atlassian.confluence.web.filter.LanguageExtractionFilter.doFilter(LanguageExtractionFilter.java:54)
	at com.atlassian.confluence.util.RequestCacheThreadLocalFilter.doFilter(RequestCacheThreadLocalFilter.java:25)
	at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
	at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
	at com.atlassian.confluence.servlet.FourOhFourErrorLoggingFilter.doFilter(FourOhFourErrorLoggingFilter.java:65)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
	at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
	at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
	at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
	at java.lang.Thread.run(Thread.java:662)
Caused by: net.sf.hibernate.QueryException: Incorrect query syntax [SELECT usr FROM com.atlassian.crowd.model.user.InternalUser usr WHERE usr.directory.id = ? AND  (usr.lowerName LIKE ? OR usr.lowerDisplayName LIKE ? OR usr.lowerEmailAddress LIKE ?)  ORDER BY usr.lowerName]
	at net.sf.hibernate.hql.QueryTranslator.compile(QueryTranslator.java:138)
	at net.sf.hibernate.impl.SessionFactoryImpl.getQuery(SessionFactoryImpl.java:295)
	at net.sf.hibernate.impl.SessionImpl.getQueries(SessionImpl.java:1570)
	at net.sf.hibernate.impl.SessionImpl.find(SessionImpl.java:1541)
	at net.sf.hibernate.impl.QueryImpl.list(QueryImpl.java:49)
	at com.atlassian.crowd.embedded.hibernate2.HibernateSearch.doInHibernate(HibernateSearch.java:102)
	at org.springframework.orm.hibernate.HibernateTemplate.execute(HibernateTemplate.java:370)
	... 215 more
Caused by: java.util.NoSuchElementException
	at net.sf.hibernate.hql.WhereParser.closeExpression(WhereParser.java:301)
	at net.sf.hibernate.hql.WhereParser.token(WhereParser.java:241)
	at net.sf.hibernate.hql.WhereParser.end(WhereParser.java:283)
	at net.sf.hibernate.hql.ClauseParser.endChild(ClauseParser.java:100)
	at net.sf.hibernate.hql.ClauseParser.token(ClauseParser.java:54)
	at net.sf.hibernate.hql.PreprocessingParser.token(PreprocessingParser.java:123)
	at net.sf.hibernate.hql.ParserHelper.parse(ParserHelper.java:29)
	at net.sf.hibernate.hql.QueryTranslator.compile(QueryTranslator.java:149)
	... 222 more
HuseinA
June 18, 2012
Hey guys, this is indeed a confirmed bug in Confluence that has been reported here https://jira.atlassian.com/browse/CONF-25775 . The current workaround is the same as suggested by Jeremy. Some users reported that the suggested flag doesn't work, but the following:
-Duser.language=en -Duser.region=US
ilter pak
June 6, 2012
We have the same problem with Confluence 4.2.3.
Please, let us know how can we fix this problem.
Thank you
Jeremy Largman
January 24, 2012
Hi Abdullah,
I know you're working through this with our support team. Our current theory is that it's related to bugs we've seen before with the Turkish Locale, like https://jira.atlassian.com/browse/JRA-22386 and https://jira.atlassian.com/browse/GHS-2463. We'll post back here when we know the solution for sure.
Jeremy Largman
January 26, 2012
For the record - and if anyone else comes across this problem - it was indeed the Turkish Locale. You can add a property (see http://confluence.atlassian.com/display/DOC/Configuring+System+Properties):
-Duser.country=EN -Duser.language=en
