How do I schedule a JIRA issue for future work?
Lionel Cassin
Let's say I want add a task in JIRA that will not require attention until some later date, e.g., the task begins a year from now, e.g., Sep 1 2013 and should conclude Oct 1 2013. So I do not want it to appear in my dashboard lists until Sep 1.
In other issue management systems (e.g., Wrike) each issue has a "start date." So it's simple to do what I want - just put in a start date of 9/1/2013. Up until 8/31/2013, I do not see the issue as active. On 9/1, the issue automatically starts appearing in my views.
But I cannot determine the similar functionality in JIRA.
I am not designing software or doing sprints, so I don't think Greenhopper is the solution, although I could be wrong.
And I guess I could make a custom filter so that items do not appear on my dashboard until their due dates are within e.g., 30 days, but that's a crude solution.
Thomas Heidenreich
August 23, 2012
we solved that the following way:
  • a new Status "Postponed"
  • a custom date field "postponed until"
  • a custom user field "assign to"
The new Status is reachable from the "New" status, the transition requires both of the new field and sets the assignee to unassigned.
Every morning a jelly script searches for issues whichs posponed until date has been reached and uses a transition which puts the issue in the "New" status und assigns is to the "assign to" user.
Norman Abramovitz
August 23, 2012
Greenhopper sprints have start and end dates. With Greenhopper 6 or greater you can now have multiple sprints, so you can assign future issues to a different sprint.
You can also do something with workflows as well, by having a state for holding issues not being worked on.
WIthout understanding your needs it is hard to give a more concise answer.
