How do I sort issues in Jira backlog and sprint?
Keren Perry-Shamir
January 23, 2019
I want to sort on various fields, like bugs / issue type, epic or assignee. I want to be able to change these sorts for various reasons in a meeting or conversation.
Is there a way to do this?
I use Jira cloud.
Looking forward to some help here :)
Nic Brough -Adaptavist-
January 23, 2019
You have to adjust the board filter to change the sort order (which is clunky and slow to do) and you will lose the ability to rank them.
Brannon Fay
November 6, 2020
If your board is built using a Saved Filter (hint: highly recommend) then you can go to a Query window and load your Saved Filter and sort how you like.  But don't save your Filter or the changes will persist to your Board and can negatively impact it.
Francesc_Arbó
January 23, 2019
+1 with @Nic Brough -Adaptavist-,
I'd suggest not to change the rank sort. If you still want to change it, you can look this link: https://confluence.atlassian.com/jirasoftwarecloud/configuring-filters-764477988.html
