How do I write a groovy expression for my workflow post-function
Ganga_Selvarajah
JIRA version: 6.4.11
(1)
Post function: Set Field Value to constant or Groovy expression
I want to set the fix version via  Set Field Value to constant or Groovy expression. I tried this script, but didn't work for me.
if(issue.get("fixVersions").getName() == "5.0.6")
return "SasS 5.0.6";
else
return "";
(2)
Post function: Transition issue
I want to transition, when the fix version is not set to "SaaS 5.0.6". I tried this script, but didn't work.
issue.get("fixVersions").getName() != "5.0.6")
return true;} else {
return false;
Please provide a solution for me to resolve these issues
Cheers.
Ganga
Ganga_Selvarajah
import com.atlassian.jira.project.version.VersionManager
def vers = ComponentAccessor.getVersionManager().getVersion(23240)
def versionname = vers.getName()
def verdesc = vers.getDescription()
if (versionname  == "5.0.6")
    return "SaaS 5.0.6";
else
   return "";
I executed this script to update fix version via post function, but it didn't work and also I am not seeing any error on JIRA log.
Petar Petrov (Appfire)
July 26, 2016
As documented here, issue.get("fixVersions") will return a collection of Version objects. Simply using getName() will not work - you need to iterate over the collection and check the name of each version object.
Ganga_Selvarajah
Thanks for the quick response.
Do you have an example, so that I can try?
Ganga
Ganga_Selvarajah
could you please provide some example? thx
Ganga_Selvarajah
Hi Petar,
I was able to set fix version using with below code via "Set Field Value to constant or Groovy expression" post function.
 def vers = ComponentAccessor.getVersionManager().getVersion(20142)
if (versionname  != "SaaS 5.0.6")
    return versionname;
My next question, I would like to stop performing a transition, if a particular fix version is set. If there any post function or code that I can use to validation this request?
Steven F Behnke
July 26, 2016
Do you get any errors on-screen or in your atlassian-jira.log file when these fail?
