I would like to understand how to automate email notification for issue which has due date coming in less than a week time as a reminder for the assignee to complete the task
Hi Ming,
You'll have to create a rule that triggers an email notification to the assignee. These steps can help you:
Step 1: Go to project settings, then click automation. (You'll see automation on the left-hand side under notifications. )
Step 2: Next, click the blue button that says create rule.
Step 3: Under triggers, scroll down until you see "schedule" and set it to daily
Step 4: Now add an action " send email"
Step: 5: Add the assignee's email, subject line and body reminding them to do issue X.
You'll also have to check the JQL box to create a condition
duedate <= startOfWeek("+7d") AND resolution is EMPTY
Note: Once the user completes the task they won't receive an email. You can also turn this rule off.
