I am looking for chart which shows recently updated for the given period ? is thera way to customize the gadgets..?
Hi Puviarasan,
It's not possible to customize the existing gadgets, however, I recommend you to take a look at the below link.
I performed an search in the Atlassian Marketplace, searching for "gadgets" and the return was the following.
https://marketplace.atlassian.com/search?hosting=cloud&query=gadgets
Using it, you can find available gadgets for Cloud, that might help you.
