How do i create a issue tracker url or what is my issue tracker url?
Preben Aanonsen
March 18, 2012
I'm trying to create an issue tracker in NetBeans, JIRA. But what is my issue Tracker URL?
Azwandi Mohd Aris
May 4, 2012
Assuming that you are using OnDemand, the issue tracker URL is just https://DOMAIN.atlassian.net (or https://DOMAIN.jira.com)
Anton Ukhanev
There doesn't seem to be an authoritative source of information on how to connect the latest NetBeans (8.0.2 at the moment of writing) to the latest JIRA (7.0.0-OD-01-193).
I installed the JIRA plugin, and tried with both https://[DOMAIN].atlassian.net and https://[DOMAIN].atlassian.net. In both cases I get error message like below:
No JIRA repository found al location. Invalid URL or proxy problem.
Jay Vyas July 15, 2016
Hi Anton,
    Were you able to resolve this problem? I, too am facing the same issue.
Darin Manica
November 18, 2016
Same problem here.  Any known solution or workaround?
Jay Vyas November 18, 2016
Hi Darin,
As far as I remember, I had this resolved as an issue with the Atlassian support team. I was told that currently the Plug-in support for Netbeans is in discontinued state and there seems to be no active development for connecting newer JIRA repositories with Netbeans. So I was suggested an option to either change the IDE or the issue tracker.
I would suggest to check with the Atlassian team again.
Darin Manica
November 18, 2016
Thank you for the reply.  Fortunately, I have this problem solved.  NetBeans 8.2 includes two different JIRA connectors.  Moving to the JIRA 5.0+ solves the issue.  I hadn't seen this option when I posted my previous comment and I don't know if it was available in previous versions of NetBeans.
image2016-11-18 13:57:42.png
Ah! Now I know... Folks hadn't updated Netbeans at my office...
Glad you were able to solve it!
Mykola Kohut
October 31, 2013
what about localhost?
