How do i create default group for JIRA users?
Endre Ron Arntsen
April 27, 2015
I am trying to give one of mye users application access to JIRA. But when I do i get this error message: "Unable to add access as there are no default groups for JIRA. Please contact support."
How  can i fix this?
Pooja Haritwal
June 24, 2015
Under JIRA Administration Go to Global Permissions on left panel - Delete Jira-users from Permission "JIRA Administrators".This will fix the issue smile
Mauro Badii
June 10, 2015
Hi Andre,
I've seen this problem happening in Cloud JIRA when the group jira-users is added to the "JIRA Administrators" Global Permissions as well.
That could be the case as well.
I created the following but to correct the messaging: https://jira.atlassian.com/browse/JRA-43794
Cheers!
Paula Silveira
April 27, 2015
Hi Endre,
You need to add this group, that should be a default one, to the permission JIRA Users. Please refer to Managing Global Permissions for further information.
Thanks and regards,
Paula Silveira
