How do i find out how many issues in a project used a certain transition?
Rahul Aich [Nagra]
June 23, 2015
Hi All
We need this info for reporting purposes.
Management want to identify how many issues in the project failed the testing.
We have a transition in workflow to identify that, so how can i identify how many issues actually used a certain transition.
Rahul
Udo Brand
June 24, 2015
If this transition is the only one between two statuses (A and B) you can use
status changed from A to B
Sateesh Chandra
June 24, 2015
Yes, enhancing Udo's query status changed from Open to Closed AFTER startOfMonth() or startOfWeek() etc.
Nuwan
I guess you can use JQL to filter issues in certain transition..
