How do i make issues marked as done visible when creating an issue link?
Şeyma İnce
July 30, 2024
When creating a link in the issue tab, only issues not marked as done are visible. Is there a way to make resolved issues appear when choosing an existing issue to link?
Adrián García González
July 30, 2024
Hi @Şeyma İnce, welcome to the Atlassian Community!
As said in this other post if you put the key of the full issue you can link to a resolved issue. It doesn't autocomplete or display it because it's Jira's behaviour and you can't change it.
I hope it helps you, best regards!
Şeyma İnce
July 30, 2024
Thanks a lot!
Like John Funk likes this
July 30, 2024
You are welcome, I would be grateful if you could accept my answer if it has helped you. Thank you, best regards!
FREE
