How do we activate issue notifications?
Eric Isaacson
August 9, 2012
Faisal
August 9, 2012
Hey Eric,
Since JIRA is not sending notifications for issues although the notifications scheme has been configured properly, I believe that this may happen perhaps because the project is not mapped to the notifications scheme. Hence, can you kindly check if the project have been associated to the notification scheme? You may go to the project configuration screen via Administration > select the project > Notifications > Scheme.
More details on this, kindly refer to the following docs:
- https://confluence.atlassian.com/display/JIRA/Creating+a+Notification+Scheme#CreatingaNotificationScheme-Associatinganotificationschemewithaproject
Hope this helps!
Cheers.
Edit: https://confluence.atlassian.com/display/JIRA/Defining+a+Project#DefiningaProject-notifications
