We have a project that requires changes to 4 applications. There seems to be no field for adding applications under projects or user stories. The closest field seems to be "Components". Does that mean the applications could be treated as components? Does it mean I have to manually add applications as components for every new project or is there another field for applications that I have missed.
I'm looking to see if I can just upload the list of all applications we have in our organization and just pick one from the list for any story instead of having them added to a project.
This is totally custom to how you visualize the terms.
Typically components are abstracted into "modules" or part of an application, such as database, gui etc.
Though several use them as application.
You could try adding a custom field for Applications, and configure it as a select list with different values for different projects (use context)
