How do you assign a project admin (not global admin) in the Web UI?
Stuart jay Stuple May 6, 2019
Having just completed the Project Admin training, i'm anxious to have the project permissions set up correctly. However, we've found that the UI we are using doesn't match what was in the training material. So we're at a loss as to how to assign someone as the admin for a specific project.
Raynard Rhodes
May 6, 2019
I believe you will need to be a global admin to set permissions (Since the scheme can be used across projects) and they will need to add the user/group/role/etc to the "Administer Project" permission.
That matches what we understand as well. But were does the Administer Project permission appear? We also believe that there is now a pre-defined role for Project Administrators (or at least there is on our instance) but that has no effect.
Raynard Rhodes
May 6, 2019
I do not have cloud, but I found this image. The top permission shows "Administer Projects". Anyone with that permission should have the ability to perform limited administrative tasks. (Anything that will not affect a scheme/multiple projects)
that looks quite likely. I'll route it to our Admins and see if that gets them unblocked.
