How do you copy components from one project to another?
Deleted user April 12, 2024
We want to set up several projects with the same components, how can we do this?
3 votes
Kalyan Sattaluri
April 12, 2024
Hello @[deleted]
If ask is using automation, you could, using Send Web request and Advanced Branching to copy these over.
  1. Trigger = Scheduled
  2. Action - Send Web request and get components from source project
  3. Create a variable and store destination project KEY
  4. Advanced Branch over {{webResponse.body}}
  5. Action-Send Web request and create components to destination project
Repeat above steps for each project by change #3's variable for destination project.
Havent tried doing this but seems logical, do try and let us know if issues or are stuck.
Guy Anela
Created an Automation Rule for this today and it worked like a charm! :) Thanks, @Kalyan Sattaluri!
 Here's a screenshot of the Rule...
Here's the configuration for the For each; Advanced branching step...
Anyhow, hope someone else finds this helpful. Cheers!
Thanks again, Kalyan!
Like # people like this
Kalyan Sattaluri
April 18, 2024
Awesome and thanks for sharing the rule. do consider accepting answer so that your solution surfaces in google searches and others can benefit in the future. Thanks!
Chanon Borgström
August 15, 2024
Hi @Kalyan Sattaluri , @Guy Anela ,
I'm trying to set up the automation and I get stuck at the get call. Have you done any special settings in the get call? It seems like the automation can't fetch anything through the API? Have experienced anything similar before?
Chanon
Guy Anela
Hi @Chanon Borgström - Are you getting any errors in the Audit Log? You'll want to make sure you have the right API endpoint URL and you have an Authorization Header defined with the proper encoded Value. Here's an example screenshot of ours...
The string that needs to be Base64 encoded should be the users email address and API Token separated by a colon (e.g. UserEmail:UserApiToken). For example...
youruser@someemail.com:aB36g87hsdHSGd&8jhdsjnn
Here's a guide on how to encode the value using PowerShell.
Once you have the encoded value, you'll want to add it to the Headers "Value" field prefixed with the term "Basic " (as depicted in the screenshot above). Notice there's a space between "Basic" and the encoded value (e.g. Basic a2XjRXTsTXNxaWP).
I hope this helps. Cheers!
Chanon Borgström
August 19, 2024
Hi @Guy Anela ,
Thanks for the clarification. I missed encoding the string with the Base64 so now it works. Thank you for this!
Wishing you a great day!
Best regards,
Chanon
Like Guy Anela likes this
Steven Yong March 23, 2025
Hi @Guy Anela Can i ask how this Automation works? Lets say i have a project BOB which has 30 components, i created a new project SAM, how does this automation copy components from BOB to SAM?
I'm getting this error:
Send web request 24/03/2025, 16:08:53 Unable to publish the web request - received HTTP status response: 500 Error found in the HTTP body response:
I've encoded my emailaddress:api_token as well
emre
     Hi @[deleted]
     We have an app that provides this feature you want.
     In the application, all components are automatically added to the Subcomponents page as content. To move these components to another project, you can press the export button and download the json file to your computer. The picture below is an image of the subcomponents page in the Configuration Management Toolkit app in one of my projects and you can do the export as in the photo.
     Then, to open a new project and import that json file, you need to click on the subcomponents page in the new project and press the import button. Then you should upload the exported file there. Then you will see this image when you load it. import screen.jpg
    Then when you press the import button, all your components will be added to the existing project and saved in Jira.
     For more details about app: https://thestarware.atlassian.net/wiki/spaces/CBSVC/pages/2287698054/Importing+Exporting+Subcomponents
     Application (add-on) link: https://marketplace.atlassian.com/apps/1211825/software-configuration-management-toolkit?hosting=cloud&tab=overview
     Disclaimer: I work for the vendor who built this app.
Deniz Oğuz - The Starware
April 17, 2024
You can use our Jira CLI too, AtlasCLI for Jira to copy all project components from one project to another. You can use the tool for synchronization too, because it will just skip over the existing components and continue to create missing ones.
jira project-component get-all --project=OLD_PROJECT_KEY | awk 'NR>2 {print $2}' | xargs -I {} jira project-component create --name="{}" --pKey=NEW_PROJECT_KEY
Just replace OLD_PROJECT_KEY and NEW_PROJECT_KEY with actual names of your projects. If you want, you can also override information for each component by passing other flags to "jira project-component create" command. Of course, you can also manipulate the component name and a project specific prefix/suffix if you want. To find out all the accepted parameters you can use the following command.
jira project-component create --help
Ste Wright
Hi @[deleted]
There's a few options here...
Ste
Victor Law
Hi @[deleted]
Jira does not support component clones natively across multiple projects.
However, it is possible to bulk-create the same set of Components via the ScriptRunner app:
https://library.adaptavist.com/entity/bulk-create-components-in-a-project
