Want to find the purpose/benefits we get by integrating Jira with the plugin 'Azure Devops for jira' and need to know the features of this plugin
Thanks for posting your question here, I am Dhiren from the Exalate Team.
Are you looking for an integration between a Jira instance and an Azure DevOps organization?
I would recommend you to try out a fully decentralized solution like Exalate in that case. It provides you a Groovy based scripting engine for next level customisations and supports sync between Jira Issues with Azure Work Items. (Any standard/custom fields can be synced bi-directionally).
Thanks, Dhiren
@Tejaswini Donga hi there. Can you, please, specify which plugin you mean? I see more than one named in this way. The integration of Jira with Azure DevOps offers a host of benefits for teams seeking streamlined collaboration and enhanced project management; consolidated view of project progress, allowing for better decision-making and increased visibility into tasks and issues. If you're looking for a tool to establish the Azure DevOps for Jira integration, feel free to check out ZigiOps on the Atlassian marketplace. It's a fully no-code tool that can connect the two and enable the data exchange. You can check ZigiOps Jira Azure integration in the Atlassian marketplace or test our free trial.
Diana
