×I want to start using this and I am clueless as to what to do.
Hi @aogundimu ,
I'd recommend some free trainings :-) :
https://university.atlassian.com/student/catalog/list?category_ids=21734-free-training
Thank you!!
Depends on what you are using it for! But to start check the top tab that says Projects, and then navigate to your line of work! You can also search by the people you know in your company under the People tab uptop as well
