How easy and flexible to Integrate JIRA with TFS
We are looking a defect tracking tool which should have a feature to integrate with TFS.
Could you please help us to get clarified how easy and flexible to Integrate JIRA with TFS?
Hi Prabakaran,
Yes you can easily integrate JIRA to TFS for any entity type, in this case defects entity. In the integration you can use JIRA as defect tracking tool while you can continue using TFS for your development. Also in this scenario the integration can be bi-directional, where in data will flow from both the tools providing traceability.
For more you can also check out this app: https://marketplace.atlassian.com/plugins/com.opshub.product.oim/cloud/overview
Thanks!
Hello Prabakaran,
You can use this addon to configure tfs with your JIRA cloud instance: https://marketplace.atlassian.com/plugins/com.spartez.jira.plugins.bork.tfs4jira/cloud/overview
It's not very hard to configure the integration with JIRA if you already use TFS.
