I see a webinar coming up for this type of connection . I want to know if it is worth the effort to connect theses 2 systems and what information can be shared?
Hi Willie, it will depend on what you are trying to achieve... What are you trying to achieve here? Connect ELM to Jira?
We (SodiusWillert) have an OSLC connector that allows you to connect IBM ELM with Jira (and it's already on the Marketplace). You can check it out here: https://marketplace.atlassian.com/apps/1221984/sodiuswillert-oslc-connect-for-jira?hosting=datacenter&tab=overview
As for what information can be shared, I suggest you take a look at this demo: https://youtu.be/SaDDbLZUpvE?si=tUdV9alBxUjUp0QW
It will give you a good preview of what you can do and the information that can be shared.
Hope this helps. Let me know if you have any questions.
I think you may be in the wrong place, your question does not seem to be about an Atlassian system. I suspect you have clicked on "help with the system in use for documentation or issue tracking" instead of "help with the product".
