How is the "default" issue order determined in JIRA issue navigator?
Daisuke Niwa
Hello there,
In JIRA, you can specify the issue order by specifing "ORDER BY" sentence on the JQL.
However, how the issue order is determined when you do not specify the above? Please let us know if you have any idea.
Daisuke Niwa
Septa Cahyadiputra
April 8, 2012
Hi again Daisuke :),
As you have mentioned, by default the issue navigator sort the list of issues retrieve by the search according to its issue keys.
Hope this answer clarify your doubts.
Septa Cahyadiputra
Daisuke Niwa
Hi Septa,
Thank you for your explanation. Understood how issue ordering works.
Daisuke Niwa
Septa Cahyadiputra
April 8, 2012
Always a pleasure Daisuke :).
Septa Cahyadiputra
Daisuke Niwa
It seems when you do not specify an order, issues are ordered in accordance with issue keys.
Please let me know if my understanding is correct.
