×Hi,
I want to have field value to be populated automatically when two or more values are filled and the result should be calculated and filled in the third field. There should not be any manual calculation and manually filling of the result field. Is it possible to do?
Also is it possible to link Jira with Excel? I mean for example, the result field should be filled automatically when it is calculated in Excel. Any possibilities of doing so?
Thanks and Regards
Shriya Chhajed
Hi!
As an answer to the first question, I'd like to recommend the following plugin:
With its help, you can populate "Calculated Text Field".
Hi Greg,
Thank you so much for the quick response.
Great! I have that plugin will try using it. It might solve my problem.
Anything can you help with linking with excel?
Thanks and Regards
Shriya Chhajed
There's a way to link Jira and Excel together but not without paid plugins and strong efforts.
I think it's much easier to use a free plugin, such as one mentioned in the previous post.
Oh Okay.
Great!
Thank you so much :)
Regards
Shriya Chhajed
You're always welcome!
Read the documentation related to the plugin, you can make any calculations you need with it.
If Excel is equally important to you, you should implement that calculated field with the Better Excel Exporter app.
The last 3 columns in this spreadsheet are calculated in real-time while creating the Excel file:
