Can you help me with the steps to migrate a complete Project from Jira Server to the Jira Cloud?
There are other options to migrate differently to using Jira Cloud Migration Assistant.
Until now, I cant to migrate using Migration Assistant.
Hi @Jose Julio
I'm also curious why you're unable to use JCMA - this is a great free option to migrate projects from Jira Server to Jira Cloud.
Since you mentioned you're looking for alternatives, there's a Marketplace app by Appfire, Configuration Manager for Jira (CMJ) on Cloud, which can perform migrations of projects from Jira Server or DC to Cloud. CMJ is ideal for teams that need to merge data into existing (in-use) Cloud sites or want to perform multiple migrations to the same cloud site because it won't duplicate data that already exists. It also has some great pre-migration cleanup and integrity checking features.
Best of luck with your migration!
Thank you very much for your time and desire to support me, I answered in the same question cro more or less what I have done if it is in your hands to correct or guide me great.
Thank you very much.
Hello.
Thank you for answering my query, I have tried to use it but I have not been successful in using it.
I have a Jira Server environment, a specific project I am interested in migrating it to Jira Cloud.
What I have done is to go to the administrative part of Jira in projects select lsitar all projects in the lower part select project configuration, then select the option export project I indicate the project I want to export in the option "export mode" I put confiuration only, however this option "Complete Project", once I select configuration only it indicates the name of the file to be exported with extension .xml I leave all the default options and say export project after about 10 or 15 minutes it generates the file.
Then I go to Jira Cloud I enter as administrator select the Project option and take the option Import Data, gives me the options Import into a new business Project and Import into or existing software project, select the option "Import into a or existing software project" is presented to the option Import Jira Server, I check the box that says I've migrated user data using the Jira Cloud Migration Assistant I give the option Import data goes through the first verification and cuadno termna the second verification tells me error
I have a doubt that when I experienced the project I definitely did not use the Jira CLoud Migration Assistant.
In the Jira server I have Jira 7.6 but it does not give me options to export the project with Jira Cloud Migration Assistant.
I don't know if with this information I can give a better view of what I want to do and if I am doing it wrong or if you can guide me.
Hi Jose,
Have you seen the instructions on this page? https://support.atlassian.com/migration/docs/choose-what-jira-data-to-migrate-using-the-assistant/
I think you're trying with project export/import, whereas the Jira Cloud Migration Assistant is a different mechanism for moving the project. Try the above and let us know if that got you what you need.
You may also want to bookmark this page which has lots of resources around the cloud migration assistant: https://support.atlassian.com/migration/docs/jira-cloud-migration-assistant/
Best,
Kelsey
Hi @Jose Julio
There are numerous tools available in the market that facilitate the migration of data from Jira Server to Cloud. However, it's important to note that migration projects are typically complex endeavors and necessitate careful planning and strategic execution.
When evaluating a third-party migration tool, consider the following criteria:
Please reach out to OpsHub’s Migration Experts, for an initial discussion on migration planning.
Brad
