I have a working integration between JIRA and Testlink. I am able to attach existing defects from JIRA to testlink test executions.
however when I try to create a new defect I get the following error
"addIssue:Failure:JIRA Message: customfield_10051 => Severity is required."
I have a severity field for a issue type "Bug" in JIRA that is mandatory.
I have tries to add this to the configuration in testlink as follows. it did not work.
Please advice.
<issuetracker>
<username>userid</username>
<password>password!</password>
<uribase>ourserver</uribase>
<uriview>ourserver/issue/</uriview>
<userinteraction>1</userinteraction>
<projectkey>OBJY</projectkey>
<issuetype>1</issuetype>
<attributes>
<customFieldValues>
<customfield>
<customfieldId>customfield_10051</customfieldId>
<type>Select</type>
<values><value>Wrong Behavior</value></values>
</customfield>
</customFieldValues>
</attributes>
</issuetracker>
Hello
Your request was solved? Please share the information with us?
Did you get any solution for this? We also have Severity as a custom field with a list of values and I need to pass the value while creating a bug.
Can you check the definition of your customfield 10051 (Severity) to see if it is restricted to a specific set of values.
The normal behaviour for Severity is that it is a select from a list of options. Your request should therefore match one of these predefined options.
I am using REST interface
