How to Add Custom Field to Team-Managed Project Work Types via API
Aditi
May 14, 2025
Hi everyone,
I created a custom field using the Jira REST API (POST /rest/api/3/field). This field is now appearing in my company-managed project as expected.
In a team-managed project, I can also see this custom field listed in the project settings under "Fields" when I click on "Add field". If I manually add the field from there and then associate it with relevant work types, the field starts appearing for those work types as well.
While I know how to do this manually via the UI, I'm wondering if there’s a way to automate this entire process through the API — specifically:
  • Adding the custom field to a team-managed project
  • Associating it with specific work item types
Is there an API endpoint or a recommended way to handle this programmatically?
Thanks in advance!
2 accepted
Tuncay Senturk
Hi @Aditi
As far as I know, Jira's REST API does not provide official support for fully managing Team-Managed Project's field configuration programmatically, as that's a project scope not global.
Aditi
May 14, 2025
Thankyou @Tuncay Senturk
Tuncay Senturk
Welcome!
Like Aditi likes this
Dilip
May 14, 2025
Yes it's not possible for team-managed project and here is the feature request you can vote for: https://jira.atlassian.com/browse/JRACLOUD-91386
Aditi
May 14, 2025
Thanks @Dilip !!
dinesh
May 14, 2025
In my project, the requirement is to set the value of a custom field using the Issue Update API. Can this be done without manually mapping the custom field to the work type through the UI? @Dilip @Tuncay Senturk
Tuncay Senturk
Please take it with a pinch of salt; to my knowledge, you cannot update a custom field via the API unless it has been added to the issue type through the UI.
dinesh
May 14, 2025
Oh, may be I ned to think about some other approach. Thank you!
