How to Bulk Add users to a Group
Paul Heath Armengol
Having to manually add hundreds of users to new groups is unacceptable.
Any way to automate it?
Ed Letifov _TechTime - New Zealand_
December 24, 2024
Hello, @Paul Heath Armengol
Just install our User Management for Jira Cloud on a trial licence, and use Bulk User Actions to select your users, including using a CSV-based filter if necessary and add them to groups in one swift bulk operation.
Reach out to our 24x7 support if required, we always happy to help.
Akolo Joseph Namo
June 7, 2025
Kieren _SmolSoftware_
December 24, 2024
Hey @Paul Heath Armengol
What criteria do you need to use when bulk adding users to groups?
Creating your own script using the Atlassian APIs would give you the most flexibility.
Using an add-on, like Admin Automations, would probably be easiest, but give you fewer options around criteria when selecting users.
Merry Christmas!
Note: I’m a Co-Founder of Admin Automations.
Valerie Knapp
Hi @Paul Heath Armengol , thanks for your question.
There have been some other posts about this so I'd refer you to this one which has multiple suggested approaches https://community.atlassian.com/t5/Jira-questions/Is-there-a-way-to-add-a-bunch-of-users-to-a-group-We-re-using/qaq-p/714657
Best wishes
