How to Copy a Project Including Issue Status & History?
Seb Kouba
I would like to create a snapshot of a JIRA Project and then make several copies so people can use them for training purposes.
To begin with we are going through different stages of a project. I would like to make exact copies of a project at that point, then continue one "branch" and leave the other as snapshot for a project at that point in time.
Script runner makes a copy of the issues but the status values are lost for example.
I also tried to export a project (search replace the key in the xml export so it's imported as a new project) and import it again but that also reset the issue status values.
Is there a way to make an exact copy?
Seb Kouba
So... I must have made a mistake when I did the system Export and Project Import.
I did that again and double checked the project and I have everything back including Status etc.
I have to do a search and replace for the issue key in the export file, then create an empty project with that key using the right schemes, then I can import.
If there is a cleaner method I would love to hear it.
Seb Kouba
Thanks for the hint. Looking at the price of "Project Clone" (seriously?!?) and functionality of the others I think we'll stick with my hack for now...
Luciano Fagundes
May 1, 2015
Hi There
You might want to try one of the 3rd party plugins that we have in marketplace.
https://marketplace.atlassian.com/plugins/com.metova.jira.project-clone-plugin
There are a few extra ones on the link below as well:
https://marketplace.atlassian.com/search?application=jira&category=&cost=&hosting=&marketingLabel=&q=project+clone
Hope it helps! smile
Cheers
L.F
