How to Create Filter With Project Permission Via REST
Luis Basilio November 1, 2018
Hey fellows,
I need to create more than 50 filters and I'd like to know how can I create them with Project Permission to All User. For now, all these filters gets issues from a unique project.
I already know how to create them, but I don't how to set the permission at the same request.
Create Filter: POST /rest/api/2/filter
"name": "Filter - Sample",
"description": "",
"jql": "project = XX AND type = "Story" ORDER BY summary ASC",
"favourite": true
Edit Filter Permission: POST /rest/api/2/filter/{id}/permission
    "id": "https://docs.atlassian.com/jira/REST/schema/share-permission-input#",
    "title": "Share Permission Input",
    "type": "object",
    "properties": {
        "type": {
            "type": "string"
        "projectId": {
            "type": "string"
        "groupname": {
            "type": "string"
        "projectRoleId": {
            "type": "string"
        "userKey": {
            "type": "string"
        "view": {
            "type": "boolean"
        "edit": {
            "type": "boolean"
    "additionalProperties": false,
    "required": [
        "view",
        "edit"
 I'd like to use the same request to create with Project Permission.
Zaheer Kazi January 17, 2023
Not sure if this is already addressed, but i have a similar situation now, so i will try doing it in three steps, 1) Create the filter 2) Get the filter ID from the response 3) Set the permissions for filter ID received in step 2)
