When I open up an Issue (ie: story, task, subtask), there is currently an area where it displays the "Issue Links" that can expand to see what issues are currently linked to one I'm viewing.
The table that it shows only shows the related issue, the priority, and status.
I would like to add to this table another column called "assigned to", where it lists the name of the assignee that the linked issue is assigned to.
Can someone show me how to do this (I"m fairly new to JIRA).
Thanks.
I'm looking for the same, there are also opened discussion here for the same question, unfortunately so far I haven't found any other solution than to use some paid add-on, for example Issue Matrix.
BR, JJ.
