How to Exclude Group values in Structre?
Deleted user March 11, 2020
Hello All,
New to structre add-on. How to exclude certain values from the Group.
Let say i have following automation set on custom fields -
Group By Customfield_A
Group by Customfield_B
resulting structre looks like below -
System (Customfield_A Value)
R1111 (Customfield_B value)
R2222 (Customfield_B value)
XC (Customfield_A)
R2121 (Customfield_B value)
R2323 (Customfield_B value)
R4141  (Customfield_B value)
Now i want to exclude only R2121 and R4141 from XC Group. How do i do that?
Please help.
Thanks in advance,
ch
Egor Tasa [ALM Works]
March 16, 2020
This issue is discussed in our support ticket, but let me mention here that S-JQL can be used to filter out certain combinations of parents and children. So if you need to remove group X only from under group Y, you can use the following statement: not (item(*, X) and child of item**, Y). For groups this can only be done either in transformation, through structure() function, or for an inserted structure (insert the structure containing groups and then add filter) - this is because grouping at the moment happens after filtering.
Egor
