How to Import Jira automation rule from one project to another
mukesh.singhal June 6, 2022
I am able to export Jira automation rule in Jason format. Once I go automation tab of another project, I did not find any option to import rule.
Any help in this regard?
Mukesh
Alex Koxaras -Relational-
Hi @mukesh.singhal and welcome to the community!
You can import rules if you go to
  • Cog > System
  • Global Automation
There you will find the option to import any rule.
Alex
Hi Alex,
Thanks for responding quickly. I can't see any options you suggest. Please see screen shot visible to me for project.
Mukesh
@mukesh.singhal you are in the project settings and not where I told you to go. So:
  • Go to Cog (upper right on your screen, next to your avatar) and click it
  • Find on the left navigation menu the option Global Automation and click it global automation.png
Bill Sheboy
June 6, 2022
Hi @mukesh.singhal -- Welcome to the Atlassian Community!
Adding to Alex's answer: you will need at least Site Admin permission to do this, so if you do not have it please ask your site admin to do the import.
Also...rather than export/import, your site admin may also copy a rule from project to another.
Like Taranjeet Singh likes this
mukesh.singhal June 8, 2022
Thanks Alex and Bill for guiding me.
I did not have access of Site admin, will connect with Jira admin to see I can get that access.
Mukesh
Like # people like this
Maksim Beliaev
why isn't a default option on the project level?
for example, one user creates a rule, shares a JSON, second user can import to the project of their choice
Bill Sheboy
November 7, 2022
Hi @Maksim Beliaev -- Welcome to the Atlassian Community!
I do not know the answer why Atlassian went that way, and here is a suggestion to allow Project Admins to import rules...without help of a Site Admin.  Please watch/vote for the issue to see progress.
https://jira.atlassian.com/browse/JIRAAUTOSERVER-83
Allen, Matthew L.
April 18, 2024
It would be nice if project admin could copy from one project to another. The copy only works within the same project.
