×I see that the Comments in a JIRA Issue is visible to all users by Default.
And, there is a 'Lock' option to restrict visibility where only Administrator & Developer Roles are listed.
Where can I configure so that all Project Roles are listed?
In the System -->General Configuration section, Comment Visibility is set to 'Project Roles only'.
Hello @Rainy
Can you explain what do you mean by all project roles?
Within this configuration you can add "project roles & groups" - which opens the doors to all of the members of this specific group to see the comment, while others are not.
Hi @Rainy ,
it is possible to select only project roles you are member of. If you want to see all the project roles, you need to be a member of all the project roles (but this usually doesn’t make sense).
