Hi Team,
Am completely new to the API testing,
Thanks in advance and really appreciate for the quick reply.
Hi @Gireesh
To export tests to JSON, you need to specify the keys, the ID of the filter or JQL query of the issues you want to export. At least one query parameter has to be specified, but all 3 can be sent at the same time.
When importing execution results using Xray JSON result format in a Continuous Integration environment, you can specify which Test Execution issue to import the results on using the "testExecutionKey" property. Alternatively, you can create a new Test Execution for the execution results and specify the Test Execution issue fields in the "info" object.
You can find information related to this in the below documentation:
Best Regards,
Team Xray
