Hi Community,
I need to migrate all data from one Jira Cloud organization (e.g., abc.atlassian.net) to another (e.g., xyz.atlassian.net). This includes:
Projects (along with issues, comments, attachments)
Boards and dashboards
Workflows, custom fields, schemes
Users and permissions
Automation rules (if possible)
What is the best way to perform this migration?
Should I use a third-party app like Exalate, Project Configurator, or Revyz?
Or is there a built-in tool supported by Atlassian for Jira Cloud-to-Cloud migration?
I would appreciate any suggestions, best practices, or references from those who have done this before.
Thanks in advance!
Hi Ayush,
I recommend using the Revyz Data Manager for Jira app in the Atlassian Marketplace.
Thank you, @John Funk Just to clarify— is Revyz a free tool, or are there any prerequisites or limitations I should be aware of before using it?
If you are willing to use a marketplace app, you can try our app Deep Clone for Jira. Deep Clone can clone whole projects and issues, including the configuration across instances. You can read more about that here.
Jira Cloud-to-Cloud migration can be more complex than it appears—especially when you want to move not just issues and projects, but also workflows, custom fields, boards, dashboards, permissions, and automation rules.
If you're looking for a more controlled and complete migration, OpsHub, an Atlassian Solutions Partner offers a purpose-built migration solution for this use case. It supports:
Here is the YouTube video to see how OMM facilitates Jira Cloud migration
Hope it helps!
