How to Restrict Users or Group to Projects
santhosh@aot-technologies.com
January 30, 2018
Team,
I have a atlassian account (JIRA) and i am created multiple projects under that.
Also i created account for all of my employees in JIRA.
Problem is every user can access all Projects. I tried Policy Restrictions but not working.
I even want to give access to clients to manage Sprint.
How can i restrict users or groups to the projects.
I did not find any help online.
Nic Brough -Adaptavist-
January 30, 2018
Remember that there is no "restrict".  Jira is permissive not restrictive.  If you want to stop someone doing something, you have to take away their permissions to do it, not restrict them.
Joe Pitt
To build on what @Nic Brough -Adaptavist- said, you need to remove the group that allows logon from your permission schemes. It is there by default, which is a bad idea and causes lots of problems.
Sreenivasaraju P
January 30, 2018
You can use Project roles for this.
More details about project roles
https://confluence.atlassian.com/adminjiraserver/managing-project-roles-938847166.html
or
you can set security for each project and enable security for the required projects only.
Security level setting details @ https://confluence.atlassian.com/adminjiraserver/configuring-issue-level-security-938847117.html
