How to Set a Default Component when create a Issue?
xinan liu
As the title says, I want to auto fill a defaule component when create a issue. Can JIRA or some plugin can do this? I have searched for some old questions about this title, the answers are all negative. Is there some more achievements?
How do I set the component field to a default value for a create (before it's entered)
How to auto-assign a 'Component' default value when creating a new issue?
Kevin Lynch February 16, 2021
Using a scriptrunner Behavior, I was able to assign a default component.
import static com.atlassian.jira.issue.IssueFieldConstants.*
// set Components
def projectComponentManager = ComponentAccessor.getProjectComponentManager()
def components = projectComponentManager.findAllForProject(issueContext.projectObject.id)
def component = getFieldById(COMPONENTS)
if (! component.getValue()) {
component.setFormValue(components.findAll { it.name in ["Component name from the list"] }*.id)
You can also assign multiple components by changing the ["Component name from the list"] to ["Component name from the list", "Other component name"]
Manvisha Kodali June 21, 2021
this worked for me, thanks :)
Vladislav
Try this as post-function:
projectComponentManager.findAllForProject(issue.projectObject.id)
def component = projectComponentManager.findByComponentName(issue.projectObject.id, "YOUR COMPONENT HERE")
issue.setComponent([component])
Amanda Lang August 12, 2019
Avinash Singh
I would also like to know if this is possible. Its seems that you can only set default values on custom fields.
