How to activate points field for JIRA stories
Mitch September 7, 2018
Hi, this feels like a silly question but I can't activate points. It is not an option in my custom fields menu.
Should I be using the numbers field? It seems like there's gotta be a specific field meant for this.
Mitch September 10, 2018
ok resolved, the 'new' Kanban and Scrum boards don't seem to have epics or estimation. F- me, there needs to be a warning about that. I wasted hours.
JIRA, you can be better than this, I believe in you.
Mohamed Benziane
Hello Mitch,
Do you mean story point ? If yes, you can read this documentation.
Regards
Thanks, did you by chance mean to add a link?
Mohamed Benziane
Here is the major problem I've having setting up JIRA. The article gives instructions that don't match what I see.
"Navigate to the board or backlog, then select more (Ellipses button) >  Board settings."
Easy right?
When I click on "..." I have the options:
"Edit Sprint"
"Delete Sprint"
There is no board settings option. I am having this type of issue on nearly every piece on online guidance I've read. I can't find epics anywhere (none of the advice works)
So, I guess... what is wrong with my JIRA instance? Where are all these incredibly obvious options that I'm supposed to have?
Mohamed Benziane
First of all go to your screen and see if the story point is here.
As an admin click on the cog icon>issue>screen>visualize those use by your project and from the action column click configure, if story point field is missing add it. Go to your issue fill the field you just have added and see if in your board is ok.
Let me know if you want further information.
Sorry for my english
Regards
