×I'm trying to add (AD) groups to project roles using the Script Runner (5.04) Console, using Jira 7.3.1. I'm trying to use the method:
void addActorsToProjectRole(Collection<String> actors, ProjectRole projectRole, Project project, String actorType, ErrorCollection errorCollection)
source:
import com.atlassian.jira.bc.projectroles.ProjectRoleService
import com.atlassian.jira.security.roles.ProjectRole
import com.atlassian.jira.util.SimpleErrorCollection
import com.atlassian.jira.security.roles.ProjectRoleManager
import com.atlassian.jira.project.ProjectManager
def projectRoleService =ComponentAccessor.getComponent(ProjectRoleService);
def projectRoleManager =ComponentAccessor.getComponent(ProjectRoleManager);
def projectManager =ComponentAccessor.getComponent(ProjectManager);
ProjectRole projectRoleObject = projectRoleManager.getProjectRole("Role Name")
Project project = projectManager.getProjectObjByKey("XYZ")
def errorCollection = new SimpleErrorCollection();
projectRoleService.AddActorsToProjectRole(['Group A'], projectRoleObject, project, "GroupRoleActor.TYPE", errorCollection)
Static type checking errors are the issue. The problem lies with the errorCollection - I am also unable to use:
projectRoleManager.getProjectRoleActors(projectRoleObject, project, errorCollection)
Can anyone help?
I changed your code a bit and it was compiled successfuly
import com.atlassian.jira.security.roles.ProjectRoleActor
Collection<String> actorCollection = new ArrayList<>();
actorCollection.add("Group A");
projectRoleService.addActorsToProjectRole(actorCollection, projectRoleObject, project, ProjectRoleActor.USER_ROLE_ACTOR_TYPE, errorCollection)
Didn't work for me. I used
GROUP_ROLE_ACTOR_TYPE
instead, and it works! 👍
BTW @Alexey Matveev Appfire_ can you help with how to add groups into four different roles in the project at the same time?
If I use in the console
four times then only first one executes.
Thanks in advance
With kind regards
Slava
Hi Slava Gefen,
I tried the code its working for me when I tried with
But I need to change the role of users.
Please suggest
Hey @Likhitha Kosanam great that it works for you. To change a role I suppose you need two actions: Remove user from a role and add them to another as described in the doc:
ProjectRoleService (Atlassian JIRA 7.1.2 API)
With kind regards
Slava
Check this out - https://community.atlassian.com/t5/Product-Apps-questions/Jira-Script-runner-add-user-to-project-role/qaq-p/230748
Below script have no static check errors. Compare your script line by line. And just adapt it to use groups instead of users.
Thanks Anton - I had capitalized the 'a' in addActors by mistake
