I would like to have an additional bar chart on the issues-panel, specifically showing the breakdown of issues Type. We are just beginning our third week of evaluation of this product (which appears excellent by the way!) and have not found faq/docs/forum that explains how to do this yet. Can you provide assistance / pointers?
Thanks in advance - Marc
Is it the 'Issue Statistics' gadget that you are looking for? You could add this to your dashboard and select the statistics as 'Issue Type'.
While that is close in concept, I am not seeing a way to place this on the issues panel itself, rather just on my dashboard. When I say issues panel, I refer to what you see when you pick a project, then the word Issues along the left edge, which then displays a number of bar graphs in the main pane.
