How to add a custom Project Configuratin Location in JIRA
Akira Tsuchiya
September 19, 2012
I added a new custom Project Configuration Location in JIRA.
A new location tab of 'BBB' is added.
And when the tab is clicked, the request is forwarded to '/secure/bbb.jspa' and
the web page of bbb.vm is displayed.
But the page is not included in the Project Configuration page.
How should I do to display the page in the Project COnfiguration page?
<web-section key="aaa" location="atl.jira.proj.config" weight="200">
</web-section>
<web-item key="bbb" section="atl.jira.proj.config/aaa" weight="1">
<label key="BBB"/>
<link linkId="bbb_link">/secure/bbb.jspa</link>
</web-item>
<webwork1 key="bbb" name="Project Configuration Test" class="java.lang.Object">
<actions>
<action name="BBBActionSupport" alias="bbb" roles-required="admin">
<view name="success">/templates/bbb.vm</view>
</action>
</actions>
</webwork1>
Akira Tsuchiya
November 2, 2012
This question duplicates with the one below.
https://answers.atlassian.com/questions/98475/project-configuration-tab-panel-error
The issue has been resoleved and the precise steps are described in the 'Answer my own question'.
Refer to the page above.
Onkar Bapat November 2, 2012
Hi Akira,
I am trying to do a similar thing. Were you able to figure out how to do it?
Hi Akira,
